Outer rear brake cable.
10 inch Terror
Xbox live gamer tag: No.
Hi all, I'm fitting a BGM rear brake outer and it seems too long. Please see attached pictures.
My question is will it be ok this long or should I shorten it slightly and replace the end ferrule? Thanks in advance Pete.
cgt75b
Main scooter: lambretta
My opinion is "leave it well alone" it will be fine.
Mag
Main scooter: Carbon GP TS1
Looks right to me
bazza3004
I cut about half inch off my outer it wasnt a bgm cable though. Think you need bit of extra length on outer for engine movement.
10 inch Terror
Cheers fellas, I'll leave it as is then.
garry inglis
mine was same 10 inch i tywrapped it to frame out the way of plug :o
HxPaul
Mine is the same length,I route my outer to the inside of the plug.
wack 63
Main scooter: '71 GP TS1
When you fit the cable plate behind the choke lever it will probably be the right length and keep it away from the plug.
    Users browsing this forum: No registered users and 47 guests
