chiselspeed dyno
garry inglis
i have just had the best day at chiselspeed i took my newbuild cassa ss200 on my 64 silver special to get dynod and set my 30mm dellorto up it also has li150 gearbox set at 4.9 franspeed supertourer bgm stater and static 17 timming and after the first run it showed the tourer was no good only coming in at 6000rpm so unrideable under this although ran on to 85000rpm and as i want this more as a tourer we decided to change to a new ads tourer and an ads race to see the differance first the ads race this ran better from 4000rpm up to 8000 then dropped off pushing out 22.5 hp and 15.3 torqe then the ads 3 it put out a lovely power curve from 3ooorpm to75000rpm putting out 19.55 hp and 15.55 torqe but mutch more rideable and this is what i went for what a lovely rideable scoot i just want to add what a great team martin has and nothing was any bother they messed about for 3.5 hours to make sure my scoot ran as good as it could and retested every time on dyno all done at a very reasonable price but the customer service and proffesional way they work is great so if you want any work done give them a call i no i will be going back :D
Tractorman
Fully agree, top place.
wayne cudine
Main scooter: Lambretta Lis150 Eibar series2
ducksta
Hi mate i stood reading your dyno graphs on the counter while buying some bits agree alot of work had been done to get good gains.
Top Man Martin, is he back to full fitness now ?
wayne cudine
Toddy wrote:Top Man Martin, is he back to full fitness now ?
He's back at work and on with a barrel for me at the moment
garry inglis
yes he just has to sit down a bit more to rest his leg
75,000 rpm .... that's some rev on. :D
garry inglis
you no what i mean just got excited
Bufficus
garry inglis wrote:i have just had the best day at chiselspeed i took my newbuild cassa ss200 on my 64 silver special to get dynod and set my 30mm dellorto up it also has li150 gearbox set at 4.9 franspeed supertourer bgm stater and static 17 timming and after the first run it showed the tourer was no good only coming in at 6000rpm so unrideable under this although ran on to 85000rpm and as i want this more as a tourer we decided to change to a new ads tourer and an ads race to see the differance first the ads race this ran better from 4000rpm up to 8000 then dropped off pushing out 22.5 hp and 15.3 torqe then the ads 3 it put out a lovely power curve from 3ooorpm to75000rpm putting out 19.55 hp and 15.55 torqe but mutch more rideable and this is what i went for what a lovely rideable scoot i just want to add what a great team martin has and nothing was any bother they messed about for 3.5 hours to make sure my scoot ran as good as it could and retested every time on dyno all done at a very reasonable price but the customer service and proffesional way they work is great so if you want any work done give them a call i no i will be going back :D
The Super Tourer does not do what it says on the tin. As you say hopeless below 6K. I tried one on My TS1 255 with 4.4 and 4.6 gearing and it was never in the power with "touring gearing". Even with 4.8 it was unpleasant and that's with 22.5 ft/lb of torque. Its also the thirstiest pipe I've had. With my latest pipe I have had to down jet two atomisers. Much more frugal. However, that has end can issues which are being resolved.
    Users browsing this forum: Google Adsense [Bot] and 1 guest
