Best way to remove bearing track on end plate.
alanscottj
- registered user
- Main scooter: Lambretta GP SS250 Casa
- Contact:
Need to replace the layshaft bearing track on the endplate. What's the best way to get it out? Heat and drift it out? Or does it need to be done by someone with a press? Thanks
Lambretta Series 2 Rat - RB260, SuperTourer, Cyclone 5 gearbox ๐๐
- registered user
- Contact:
It usually won't be that tight that it needs pressed out.
You should be able to knock it out wth a suitably sized socket.
Knowledge
- Dealer
- Main scooter: GP
- Contact:
This is the way to go. Use two sockets; one to push the bearing out, and one (larger) socket to push the race into. Gently does it.Muppet wrote:y use a vice a piece of tube or pipe and somthing to space out the endplate
Martin
alanscottj
- registered user
- Contact:
Cheers fellas, old one out and new one in. A bit of heat and a couple of sockets as suggested, did the trick
I was very surprised at the difference a new track makes, the old one wasn't in that long either (off eBay though
this time I got a new bearing and track from Andy Francis and they fit nice and snug together, quality
- registered user
- Contact:
Probably been your problem, the old eBay one might not have been properly hardened.
alanscottj
- registered user
- Contact:
I hope so, will know later when I get it back together. What is the best way to have the rear wheel whilst I shim the gearbox? On the little stand or not? I believe it makes a big difference?rosscla wrote:Probably been your problem, the old eBay one might not have been properly hardened.
alanscottj
- registered user
- Contact:
Cheers Muppet, all done now. Was all going well until the last end plate bolt decided to knacker it's thread so now I have 5 out of 6 bolts only on end plateMuppet wrote:on a stand wheel off ground
- Information
Who is online
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 2 guests
