Best way to remove bearing track on end plate.
alanscottj
Need to replace the layshaft bearing track on the endplate. What's the best way to get it out? Heat and drift it out? Or does it need to be done by someone with a press? Thanks :D
Muppet
y use a vice a piece of tube or pipe and somthing to space out the endplate
Cโ€™est la vie
They Usually knock out with a drift
It usually won't be that tight that it needs pressed out.
You should be able to knock it out wth a suitably sized socket.
Knowledge
Muppet wrote:y use a vice a piece of tube or pipe and somthing to space out the endplate
This is the way to go. Use two sockets; one to push the bearing out, and one (larger) socket to push the race into. Gently does it.
Martin
alanscottj
Cheers fellas, old one out and new one in. A bit of heat and a couple of sockets as suggested, did the trick :D
I was very surprised at the difference a new track makes, the old one wasn't in that long either (off eBay though :roll: this time I got a new bearing and track from Andy Francis and they fit nice and snug together, quality :D
Probably been your problem, the old eBay one might not have been properly hardened.
alanscottj
rosscla wrote:Probably been your problem, the old eBay one might not have been properly hardened.
I hope so, will know later when I get it back together. What is the best way to have the rear wheel whilst I shim the gearbox? On the little stand or not? I believe it makes a big difference?
Muppet
on a stand wheel off ground
Cโ€™est la vie
alanscottj
Muppet wrote:on a stand wheel off ground
Cheers Muppet, all done now. Was all going well until the last end plate bolt decided to knacker it's thread so now I have 5 out of 6 bolts only on end plate :oops:
    Users browsing this forum: Ahrefs [Bot], Semrush [Bot] and 4 guests
