Removing Bottom Bearing Cone
TurboTrev
Has anyone got any tips or techniques for removing the bottom bearing cone from the frame? On my last one I heated the frame and banged the outer edge until first, the cone cover split and broke off then eventually the cone itself came out, but it was a right so and so to do. Does anyone have a better way of doing it? Is there a removal tool? Thanks.
I use a long metal drift down the frame tapping gently either side of the cone if tight I use a bit of heat
HxPaul
If you get "Sticky's manual" it tells you the best way's to remove the cone on pages 212-213.
TurboTrev
^^^Thanks chaps. Just looked in my book, I forgot those tips were in it!
