Gearing
Finny
Main scooter: Lambretta series2
Running rt195, mg clubman ,gp200 gearbox, 47 x 18 sprocket. All this is a final drive of 5.2. Thinking of getting nearer a final drive of 4.8. Changing drinker sprocket to a 20 with a 83 link chain appears the cheapest and easiest way to get near 4.8 (actually gives a final driv of 4.7).
Kit is described as able to cope with this final drive.
Are there any problems I might encounter. Would the sacrifice of low end make riding s pig (only ride one up and a mix of dual carriage ways, traffic, rural bends with slow elderly couples driving to somewhere to have a flask of tea!).
Thanks
HxPaul
Finny
Thanks. Want to try and avoid changing gearbox. Any run a similar gearing set up 47,20 and 83 chain?
YAMLAM
why not go 19/46, gives 4.84 18 x 47 chain should fit.
win or lose have a booze
Muppet
YAMLAM wrote:why not go 19/46, gives 4.84 18 x 47 chain should fit.
+1 this mite be betta
C’est la vie
Grumpy225
That's what I run on mine and get a true GPS verified 70mph out of it.
24 dellorto
BGM V2 box exhaust
Finny
Thanks for replies. Taken advice on board and goin with 46x19. Next issue is exhaust...............
ducksta
19x46 with a 400/10
YAMLAM
Running rt195, mg clubman thought you already had exhaust ??
If you change the exhaust then all the above info goes out of the window.
