and the muppet of 2015 is.........................
bristolmod
"bristolmod"
last week I decided to change the disc pads on my TV175S3. So removed the hub; stripped it down; cleaned it; replaced with new pads, and rebuilt it.
Had problems refitting the front hub/ wheel to the links, but eventually got it in- put it down to my advancing years/ failing eyesight. Brakes worked fine but working on the front noticed a slight lean to the N/S.
Today I removed the wheel/ disc and replaced the buffers- same problem getting the unit back into the links.
"Somethings not right" says bristolmod
After a very long think and reference to the original 1962 parts book., I discovered to my absolute horror that I'd fitted the axel the wrong way round (had the "shoulder" on the N/S and the nut on the O/S :shock: )
I've gone for a long lie down and am contemplating my scootering future..................
Scootering since 1968.
dave411
Main scooter: Li 125
Hey,we all make mistakes.The good thing is you found it :)
10 inch Terror
Xbox live gamer tag: No.
Doh!!
shamrockexpress
I would have said nothing...................so you are at least an honest muppet :D :D :D
so easily done matey :)
bristolmod
if this was the Officers Mess and I was a Gentleman, I'd be left alone in a room with the RSM's Webley, and be expected to do the right thing............. :D
warts
Main scooter: honda
And the 2015 equivalent of that is... being given a knighthood and being awarded lucrative govt contracts.
railfancwb
warts wrote:And the 2015 equivalent of that is... being given a knighthood and being awarded lucrative govt contracts.
True that!
I had a disc hub sent back from Beedspeed in this fashion a few years ago.
