Lambretta cylinder head damage
DickieD
Main scooter: 1970 GP 200
Rebuilding my brother-in-laws Mugello 186 motor ant the cylinder head has a lot of pitting etc from when the small end bearing fell apart. Can anyone tell me if this can be clean up and used or is it better to get a new cylinder head?
Image20150520_165756 by Paul Davies, on Flickr
bristolmod
I'd say clean up and use.
Scootering since 1968.
mick1
Main scooter: Li Avanti 225
Maybe give it a skim and use a thicker head gasket
DickieD
Thanks for replies might just clean it up and see how it goes.
Paul
mick1
i'd leak test it before use. suck in a bit of air and you may hole the piston
onthelam
Main scooter: not yet
:idea: If you have a dremel with small sanding cylinders
don't use the tool but just sand the squish band to knock of the sharp bits . Then finish off with some finer 200 grit. The sharp edges will promote detonation if the engine is prone to it. It doesn't have to be like a baby's bum but the smoother the better. This method involves time, effort and dust. ;)
DickieD
Cheers for advice so far. I have managed to get out the garage today and clean up the head but still not 100% happy with it. Some of the damage is deep. Has anyone ran one like this without any problems. If it was for me I would run it as is but it's not my money so need to make sure.
Image20150526_161805 by Paul Davies, on Flickr
Muppet
skim reprofile
C’est la vie
DickieD
Cheers Muppet,
That is one option, he is on a tight budget so don't really want to buy a new head.
Grumpy225
You should really have the damaged part cut off the head and then run a thicker head gasket to make up the height difference. I'm sure after all that sanding work the sealing surface if far from flat and will always cause problems.
