Lambretta cylinder head damage
DickieD
Main scooter: 1970 GP 200
Rebuilding my brother-in-laws Mugello 186 motor ant the cylinder head has a lot of pitting etc from when the small end bearing fell apart. Can anyone tell me if this can be clean up and used or is it better to get a new cylinder head?
Image20150520_165756 by Paul Davies, on Flickr
bristolmod
I'd say clean up and use.
Scootering since 1968.
mick1
Main scooter: Li Avanti 225
Maybe give it a skim and use a thicker head gasket
DickieD
Thanks for replies might just clean it up and see how it goes.
Paul
mick1
i'd leak test it before use. suck in a bit of air and you may hole the piston
onthelam
Main scooter: not yet
:idea: If you have a dremel with small sanding cylinders
don't use the tool but just sand the squish band to knock of the sharp bits . Then finish off with some finer 200 grit. The sharp edges will promote detonation if the engine is prone to it. It doesn't have to be like a baby's bum but the smoother the better. This method involves time, effort and dust. ;)
DickieD
Cheers for advice so far. I have managed to get out the garage today and clean up the head but still not 100% happy with it. Some of the damage is deep. Has anyone ran one like this without any problems. If it was for me I would run it as is but it's not my money so need to make sure.
Image20150526_161805 by Paul Davies, on Flickr
Muppet
skim reprofile
C’est la vie
DickieD
Cheers Muppet,
That is one option, he is on a tight budget so don't really want to buy a new head.
Grumpy225
You should really have the damaged part cut off the head and then run a thicker head gasket to make up the height difference. I'm sure after all that sanding work the sealing surface if far from flat and will always cause problems.
    Users browsing this forum: Ahrefs [Bot] and 4 guests
