t5 172 carb set up
soulboy
just put a 25 mm carb with polini filter on and it bogs down in every gear ..with out the filter its a bit better so am I to rich
soulboy
its taking longer than it should to fall on tickover can anyone tell me whats causing this ive taken the filter off
ipman
:roll: :lol:
acko
soulboy wrote:its taking longer than it should to fall on tickover can anyone tell me whats causing this ive taken the filter off
Sounds lean to me.
Better to be someone for a day than no-one for a lifetime
soulboy
yes but at the top end its a bit rich the needle is on the top slot its got a 130 main jet in any help would be gratefull I remember on my 172 dragster with a 25 mm carb the main jet was only about 105/108
soulboy
yea cheers all :evil:
sounds to me that you need to get this set up properly on a dyno ,its rich on the top end but weak with possible air leaks at low revs ...
    Users browsing this forum: Amazon [Bot] and 4 guests
