t5 172 carb set up
Sounds lean to me.soulboy wrote:its taking longer than it should to fall on tickover can anyone tell me whats causing this ive taken the filter off
Better to be someone for a day than no-one for a lifetime
- registered user
- Main scooter: t5 172 and a bit more
- Contact:
yes but at the top end its a bit rich the needle is on the top slot its got a 130 main jet in any help would be gratefull I remember on my 172 dragster with a 25 mm carb the main jet was only about 105/108
- sean brady scooters
- Dealer
- Contact:
sounds to me that you need to get this set up properly on a dyno ,its rich on the top end but weak with possible air leaks at low revs ...
