Barrel Base Sealing
Starwave
Hello
To set the squish on my Lamby I'd like to fit a 1mm head gasket and omit a base gasket.
So.......should I use Blue Hylomar or clear silicone (Dow Corning 732) on the base of the barrel? Tis a Rapido 225 if it makes any odds.
Apologies if this has been discussed at length before.
cheers
Loctite copper silicon 5290
handofdave
Main scooter: li ts1
rosscla wrote:Loctite copper silicon 5290
thats what i use too
Starwave
Super job, in which case I shall use it too.
Cheers gents
Muppet
http://www.henkel-adhesives.com/product ... 9373918209
5290 for circuitboards? starwave you have a pm
C’est la vie
shamrockexpress
High temp hermitite red never fails for me although its now hard to find!!!!!not sure if its discontinued or superceeded with a new product maybe some others on here know were to get it........
Muppet wrote:http://www.henkel-adhesives.com/product ... 9373918209
this stuff
bazza3004
never had a problem when using clear silicone . don't think the blue hylomar actually sets .
Starwave
I think 5290 was a typo, and was meant to be 5920. Picked some 5920 up today from Halfrauds.
Ai, blue Hylomar doesn't set, which is one attraction when pulling things apart, but its gap filling properties aren't as good as silicone. Easy to get the two components apart and clean up. Silicone sets even before clamping the faces together as it's moisture in the air that sets it off.
I mentioned blue Hylomar and Dow Corning 732 clear silicone as they were the two most likely looking sealants in me garage.
Thanks for the PM.
Yes, my typo, sorry.
