Handlebar Lever
kejj
Do anyone know if the Vespa and Lambretta Handlebar levers för clutch and brake are interchangeable?
IE, can I buy one for a Vespa and fit it to my Lambretta?
________________________
http://tv175.wordpress.com/
They're not identical, if you get Vespa ones I think you need to fettle them to fit...
Monty
Vespa PX on a series 1 or 2 yes
Series 3 or better no due to the shape of the lever support
kejj
Thank you for the replies.
I mostly wondered if they have the same connecting holes at the same spot.
Monty
The series 1/2 are identical for pivot point and bolt size. It was overall a bit fatter (thicker where it meets the lever support) but only by about 1mm so was easy to adjust and polish. I was after the dog leg levers and could not find any lambretta ones
Tractorman
Where did you get the PX levers from, please Monty?
Monty
Tractorman wrote:Where did you get the PX levers from, please Monty?
Ebay Scooter emporium old stock. They were originally painted red. When I got the paint off the aluminium was a rough casting that needed polishing up but the size and shape should be the same if you can get some already polished.
Tractorman
Thanks, Monty
kejj
Intresting. I was looking at these:
http://beedspeed.com/images/LambrettaLe ... stable.jpg
But only see the hole for the bolt not the wire barrel.
In Lambretta we trust!
It must go underneath outboard of the adjustor
