Handlebar Lever
kejj
Do anyone know if the Vespa and Lambretta Handlebar levers för clutch and brake are interchangeable?
IE, can I buy one for a Vespa and fit it to my Lambretta?
________________________
http://tv175.wordpress.com/
They're not identical, if you get Vespa ones I think you need to fettle them to fit...
Monty
Vespa PX on a series 1 or 2 yes
Series 3 or better no due to the shape of the lever support
kejj
Thank you for the replies.
I mostly wondered if they have the same connecting holes at the same spot.
Monty
The series 1/2 are identical for pivot point and bolt size. It was overall a bit fatter (thicker where it meets the lever support) but only by about 1mm so was easy to adjust and polish. I was after the dog leg levers and could not find any lambretta ones
Tractorman
Main scooter: Lambretta li150 special
Where did you get the PX levers from, please Monty?
Monty
Tractorman wrote:Where did you get the PX levers from, please Monty?
Ebay Scooter emporium old stock. They were originally painted red. When I got the paint off the aluminium was a rough casting that needed polishing up but the size and shape should be the same if you can get some already polished.
Tractorman
Thanks, Monty
kejj
Intresting. I was looking at these:
http://beedspeed.com/images/LambrettaLe ... stable.jpg
But only see the hole for the bolt not the wire barrel.
In Lambretta we trust!
It must go underneath outboard of the adjustor
    Users browsing this forum: Ahrefs [Bot] and 1 guest
