Exhaust Temp
- registered user
- Main scooter: Lambretta Li150
- Contact:
Any one know what sort of temp a standard Li 150 exhaust reaches. I'm wanting to paint the exhaust but I've seen 400 600 and 800 degree paint. Prices vary wildly so just wondering which one to use.
- registered user
- Main scooter: Vespa T5 Classic
- Contact:
PlastiKote Industrial High Heat spray is well worth a try, philz....I've always had great results with it, and it lasts.
It dries with a sort of powdery finish, but it buffs up really nicely with a microfibre cloth.
I usually do one coat and allow to dry, then wipe / buff away the powdery finish and then repeat before fitting...then just allowing it to cure with heat.
You can pick it up at Screwfix for £5.91 a can at the mo.
