Exhaust Temp
philz
Main scooter: Lambretta Li150
Any one know what sort of temp a standard Li 150 exhaust reaches. I'm wanting to paint the exhaust but I've seen 400 600 and 800 degree paint. Prices vary wildly so just wondering which one to use.
philz
Bump
mick1
Main scooter: Li Avanti 225
Not sure on the temp but i find the BBQ paint pretty good. I use the brush on type and other than the U bend it lasts for quite a while.
philz
Cheers mick1
Snapper
Main scooter: Vespa T5 Classic
PlastiKote Industrial High Heat spray is well worth a try, philz....I've always had great results with it, and it lasts.
It dries with a sort of powdery finish, but it buffs up really nicely with a microfibre cloth.
I usually do one coat and allow to dry, then wipe / buff away the powdery finish and then repeat before fitting...then just allowing it to cure with heat.
You can pick it up at Screwfix for £5.91 a can at the mo.
philz
Thanks guys I will take a look at both products.
