Warm starting not
jazzyb
Hi peeps before I go and pester waddo my mates 150 special starts first kick runs a dream but when warm a b••stard to start not great we engines so be kind Bog standard with 175 kit fitted years ago no other probs at all thanx jazzy 8-)
mick1
Main scooter: Li Avanti 225
Restricted air flow or to much fuel. Choke sticking might be an option ?
Bilko
Main scooter: LI150
Worn rings?
Bilko's Oily Blog
nuttyboy
Main scooter: lambretta
Had same problem was air leak in split carb rubber.
Sent from my KFTT using Tapatalk 2
Mr G in NYC
Main scooter: SX200
not in any order but have a look at......
Spark plug gap/ correct plug ?
Float needle worn ?
Blocked or worn pilot jet ?
Blocked air filter
choke cable seated correct ?
I have a stock DL 200 thats a bitch to start after a run .
So now I switch off the fuel just before I stop and run
the carb bowl half empty ........Then when I restart it
I leave the fuel tap and choke off and it starts first kick.
Stock old SH/22 dellorto that one of these days I'm gonna
swap out for a NOS one I have sitting in the garage...
Good luck bud 8-) G 8-) .
jazzyb
Cheers all thanx g it's Steves golden special who popped in to c u with me last year 8-)
rainbowrunner
Main scooter: Series 2, RT 195
I,m having the same problem (only now and again tho) 175 top end, new everything, all run in etc from cold starts first kick with choke, switch off at garage for fuel starts again first kick, problem is if i leave it 10 or 15 mins it can be a bitch, been told it could be my pilot jet, got in a 50 ! would a 45 or 48 be better.
plugs a nice colour and no air leaks
