sandblasting problem
mickey
ok so i just sandblasted my legshields using crushed glass and now i have a metallic looking finish, caused probably by too high a pressure. can i get away with priming over this or do i need to sand it all off.
mickey
ANYONE?
Stampede
Main scooter: SX200
No, that´s the rule with crushed glass, you´ll get a very smooth surface compared to the "real" sandblasting.
You get residue embedded in the surface with grit blasting too, it will sand off very easily either by hand or with a flap wheel. Something like 80 grit should do it.
mickey
k thanks a quick rub down it is then :D
    Users browsing this forum: No registered users and 52 guests
