5 plate clutch !!!!
ServetaDave
- registered user
- Main scooter: Serveta Jet 200
- Contact:
Fitted a new 5 plate clutch (Cambridge Lambretta supplied) to a brand new Indian GP200 engine. It is quite a heavy pull on the lever....grrrr. Split casings & checked brass actuator still doing its actuating things, all springs in place. Is it heavy because its new??? Is the final steel plate too thick for the GP200 engines??? If anybody has any thoughts/past experience please share. I'm off to power lift things with my left arm before I go a run
mick1
- registered user
- Main scooter: Li Avanti 225
- Contact:
For over a year i ran with a heavy clutch, burnt it out twice before i realised it was the cable !! Some of the strands on the inner cable had frayed, felt perfectly fine when disconnected but once the clutch was connected you needed arms like Popeye to work it. Fitted a new cable and it's one of the lightest clutches i've used.....
ServetaDave
- registered user
- Contact:
Cheers Mick I'll try a new outer inner combo
ServetaDave
- registered user
- Contact:
Cheers Timbo
- Information
Who is online
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 4 guests
