Apria 125
sydduckett
couple of years back at iow Frank Sanderson had a load of bikes outside the ice rink one of which was a geared Apria 125. It seemed to fit into a series 3 without widening from memory although that may not be the case. Anyways looked on his site and there is a bit about a series 4/5 with an Apria 125 conversion but doesn't mention gears.
Anyways can anyone confirm what specific donor bike this geared engine would come from?
thanks
Sef
jackson85
Main scooter: T5mk1
Twas a rs125 six speed engine. 30 odd horses, plus polini do a kit for them.
sydduckett
Cheers, do they do both air and watered cooled versions? Also the engines from an Apria bike not scooter right? thinking about gearing
Ta
jackson85
Main scooter: T5mk1
Liquid cooled rotax. Great craic to go in the bike version anyway. They do the ton. That said, beasting well probably be a pain, since they run a 17 inch wheel as standard
sydduckett
Ta for that. By beasting do you mean gearing? I'm presuming changing the rear sprocket and maybe the front should sort the gearing.
sydduckett
Been looking at some on gum tree. we're the early ones 2 stroke and the later ones 4 stroke? also Some are "full power", was this a factory option or owners upgrades?
Ta
sydduckett
sydduckett wrote:Been looking at some on gum tree. we're the early ones 2 stroke and the later ones 4 stroke? also Some are "full power", was this a factory option or owners upgrades?
Ta
should have gone on Wikipedia first. Seems 2006 onwards are the ones to go for. No mention of the "full power" though.
e type
The geared version is the rs 125 ...the auto is a sr 125 same as a gilera runner or italjet dragster engine ..both completely different the series 4/5 is auto the series 6 is the rs125 geared bike engine
sydduckett
e type wrote:The geared version is the rs 125 ...the auto is a sr 125 same as a gilera runner or italjet dragster engine ..both completely different the series 4/5 is auto the series 6 is the rs125 geared bike engine
Ah, Ta for that. spent some time looking at reviews. Seems that the engines are liked tuned lammie ones, ie go pop without warning....w :D
soulboy
they were watercooled strokers 21bhp and 12 bhp very good motor if it was me id go for a 250 crosser engine there small cheap and rip ur arms off as for blowing up the reason for that was kids not looking after them that's all very good motors and in a scooter frame u would be a fekin good rider to max it
