Mikuni TMX exploded view
carlos fandango
Mikuni TMX35mm
o. Description Part No.
1 Mixing Body Carb TM38SS11
2 Jet Needle J8-SEE TUNING
3 Cover, Carb Top 776-19014
4 Lock Nut, Adjuster B30/247
5 Cap, Rubber VM34/282
6 Adjuster, Cable VM30/77
7 O-ring, Top Cover 616-93009
8 E-ring, Needle Clip BS32/126
9 Ring, Retaining TM38/54
10 Adjuster, Idle Stop 603-25008
11 Spring, Idle Adjust N110209
12 Plunger, Starter Assy TM38/57
13 Screw, Air Adjuster 603-36002
14 Spring, Air Screw VM15/112
15 Chamber, Float Bowl TM38/48
16A Valve Seat, NDLE Assy 786-36004-(2.5)
16B Valve Seat, NDLE Assy 786-36004-A-(1.8)
17 Pilot Jet VM22/210-SEE TUNING
18 Main Jet 4/042-SEE TUNING
23 Cap, Float Retainer VM26/42
24 Screw, Top Cover CW2=0412
25A Throttle Valve 999-832-014
25B Throttle Valve 999-832-017
26 Spring T.V. 730-13019
27 Hose, Vent 888-24011
28 Screw, Float Bowl CW2-0308
29 Hose, Overflow 888-23022
30 Float, Left Side 859-52021
31 O-ring, Drain Plug BN042/64
32 Drain Plug TM38/44
33 Float, Right Side 859-52020
34 Gasket, Float Bowl TM38/52
oldbiker
A very similar carb is the mikuni TM 28 as fitted to the 1987-89 yam tzr250, the diferences are: it is a 30 dergree down draft carb. has a power jet, no air screw. these carbs are easy to set up
If you do pick one of these up it will almost certainly need a new float needle and a float bowl gasket, a few £
If the emulsion tube and needle need to be replaced look at about £40, but these do tend to be in good condition even on very old carbs
mounting details:
spiggot size is 35 mm od, with a groove for carb rubber 3mm from the end of the spiggot
the part numbers are the yamaha part numbers
mikuni parts: try NRP in manchester.
http://www.nrp-carbs.com
email [email protected]
GP Kevo
carlos fandango wrote:Mikuni TMX35mm
The TMS slide is used to do away with the main jet and use special Jet Needles instead.
The TM 28 is a very different carb to the TMX series. The TM 28 (even the OEM ones) are Flat Slide Mikunis where the TMX is a modified D slide. The late model TMX (with electronic choke) is a full D slide.
