IS THIS REED BLOCK OK FOR A TS1
davyjj
Main scooter: GP 200 TS1
I hope these pics upload ok....... :roll:
If so, do you think they are good enough to be fitted to a TS1 fitted with a 34 VHSB?????
http://s780.photobucket.com/user/davyjj ... 7.jpg.html
http://i780.photobucket.com/albums/yy81 ... c2ff5e.jpg
DaveTomo
Main scooter: SX 200
copy and paste the IMG part mate & if you want to double check hit preview so you can see if its worked. ;) no idea about the reed block though
davyjj
THANKS Dave !!
bizzly
It looks like the same one I have on my TS1, but I have a packer plate on mine with a Mikuni 35tmx
looks like yamaha rd reed .. and has been milled to clear frame better .. can use as is with steel reeds
davyjj
OK thanks! Think I'll stick with it. Seen the exact same one on AF Rayspeeds site so it must be fine. New MB inlet manifold and rubber on its way, so should be good to go :D
