series 2 rear light
leigh
doing up a series 2 lammy for a friend. has 3 festoon bulbs in the back light.
which ones are the brake etc
leigh
Wouldn't it be better to fit the larger, later unit so that you can use a standard reflector and bulb? Unless your friend is set on originality.
leigh
he is after original
leigh
DigDug
leigh wrote:doing up a series 2 lammy for a friend. has 3 festoon bulbs in the back light.
leigh
3 lamps
2 functions, 1 is brighter than the other...................... ;)
Did you have to do that?
diesel
The two sides are the brake lights,the centre is the driving light and plate illumination
leigh
cheers thanks
Those things are worst than most cycle lights. If he wants to keep the original looks but get safer lighting he could fit a BGM LED board instead of the crappy 3 festoon setup.
Rotor
Main scooter: 1960 S2 Italian
corrado wrote:Those things are worst than most cycle lights. If he wants to keep the original looks but get safer lighting he could fit a BGM LED board instead of the crappy 3 festoon setup.
yep have to agree there, trying to get the right length festoons and poor light output, BGM do 6 & 12V version(s) for around £25 its the best bang for buck/ smallest amount of money you could ever spend on a Scooter just fit and forget, not to mention safety issues.
Paul
