Outer gear cable help
boonyed
I know I could sort this by trial and error......but!
I have put new outer gear cables through a repainted frame and need to reconnect the inner cables to the selector. Which way round do they need to go at each end? Is there an easy way to remember whether the cable nipple on the upper side of the handlebar wheel goes on the inside or the outside of the selector?
Many thanks in advance
gaz_powell
Front to Back and Back to Front
the front cable (nearest headlight) on the gear wheel in the headset goes to the back adjuster on the selector
the rear cable (furthest headlight) on gear wheel in th eheadset goes to the front adjuster on the selector
boonyed
Thanks Gaz - top man
ducksta
just put cables in at top connected, then hold them at bottom get mate to turn lever towards 1stthe inner cable that starts to shrink goes towards the engine the other goes on the outside, put some black tape on the inner outer cable so if you strip you always no which goes where
    Users browsing this forum: No registered users and 26 guests
