60mm crank
RAP 200
When fitting a 60 stroke crank does ignition timing change;ie,iff timing is set at 18 deg btdc with a 58 stroke and then a 60mm stroke crank is used does stator stay in the same place, and do you still get 18 deg.
if its a new crank id say check the timing in thery the keyway should be iin the same place in relation to the crank at top dead center are you running a 1mm packer :?:
squeakmillward
no it doesnt change
So, theorectically, is the woodruff key slot always in the exact same place on various cranks?
jason frost
When you change any part( crank, piston, flywheel, stator) timing should be checked.
