brake problem
bald-scooterist
Xbox live gamer tag: wtf is this s**t
Playstation gamer tag: wtf is this s**t
Main scooter: GTS300
Front brake on my gts is dragging, any idea why?
gears are for queers
cgt75b
Main scooter: lambretta
Air in the lines. Give it a bleed with with new fluid should then be ok
Play in the front wheel bearing or sticking piston or pads?
bald-scooterist
cgt75b wrote:Air in the lines. Give it a bleed with with new fluid should then be ok
how do i do that?
cgt75b
Get a brake bleeding kit. Have a look on the web it will show you how :D
bald-scooterist wrote:Front brake on my gts is dragging, any idea why?
does the brake work but then not release ? if so then its the pots in the caliper sticking allthough this tends to happen if been stood a while
