brake problem
bald-scooterist
- Xbox live gamer tag: wtf is this s**t
- Playstation gamer tag: wtf is this s**t
- Main scooter: GTS300
Front brake on my gts is dragging, any idea why?
gears are for queers
Air in the lines. Give it a bleed with with new fluid should then be ok
bald-scooterist
cgt75b wrote:Air in the lines. Give it a bleed with with new fluid should then be ok
how do i do that?
Get a brake bleeding kit. Have a look on the web it will show you how
does the brake work but then not release ? if so then its the pots in the caliper sticking allthough this tends to happen if been stood a whilebald-scooterist wrote:Front brake on my gts is dragging, any idea why?
