HT lead
diesel
Can modern carbon HT leads such as those available in a halfords be used on SIL 12v Electronic set ups?.
tony
Main scooter: 90ss
In theory yes.The problem is that you can't really use a screw in type Ngk ht cap or screw the lead into the cdi as the carbon breaks up.
diesel
Cheers Tony that's what I needed
tony
Main scooter: 90ss
no prob mate.. that type of lead is usually suppressed also. I had to run them on an ignition I used to use. But I used a bosch type car coil on the other end so a push in connector was ok.
    Users browsing this forum: Amazon [Bot] and 1 guest
