Bloody Spring!!!!!
sdugg
Please tell me there is an easy way of putting on a centre stand spring.
Tried stand up , scoot lent over , spring puller and then me not being strong enough to pull the bloody thing.
Any usefull tips....
Liverpool Scooter Club
Lambretta Club of Ireland
slot some pennies or washers in between a few of the coils, hook it over, then pull them out.
or fit the spring as you're fitting the stand
bristolmod
funnily enough I've just done a mates this afternoon.
1) Hook it on the top
2) put a strong screwdriver in the lower hook
3) Put the end of the screwdriver under the attachment on the stand
4) Pull the spring down using the stand attachment as a fulcrum
5) The lower hook of the spring will slip over the stand attachment
Be warned- the spring is strong and it may slip off the screwdriver. Mind your eyes/ body/ fingers- it hurts :D
Chris
Scootering since 1968.
joespeed
there is a proper tool for this ,it is like a screwdriver but the blade is curved,i personally use a screw driver guided by a pair of pliers ,when the spring 'twangs' so does your temper!
regards
joe
bristolmod wrote:funnily enough I've just done a mates this afternoon.
Chris
This method works for me too but I'll be trying Byron's method next time I do it. cheers Jarv ;)
hydra
As said already, by far the best way is to fit the spring to the stand and frame and then fit stand bolts.
rog60
Main scooter: Indian GP200
hydra wrote:As said already, by far the best way is to fit the spring to the stand and frame and then fit stand bolts.
Same here, by the time you've f**ked about with the spring you could have undone the stand bolts. :!: :!: :!: :!: :!:
Ditto...but I did use byrons method last year from his advise cheers byron..
RBG
I attach it before fitting the stand.
simon
I used a big screwdriver doing the series 2, it scraped the paint on the stand tho :ugeek: was to lazy to take the stand off :mrgreen:
    Users browsing this forum: No registered users and 20 guests
