Please tell me there is an easy way of putting on a centre stand spring.
Tried stand up , scoot lent over , spring puller and then me not being strong enough to pull the bloody thing.
Any usefull tips....
Bloody Spring!!!!!
bristolmod
- Main scooter: Lambretta TV175 S3- what else!
- Location: Bali-Hai bar, Locarno Ballroom Bristol, 1967!- mines a Brown Split!!
funnily enough I've just done a mates this afternoon.
1) Hook it on the top
2) put a strong screwdriver in the lower hook
3) Put the end of the screwdriver under the attachment on the stand
4) Pull the spring down using the stand attachment as a fulcrum
5) The lower hook of the spring will slip over the stand attachment
Be warned- the spring is strong and it may slip off the screwdriver. Mind your eyes/ body/ fingers- it hurts
Scootering since 1968.
joespeed
there is a proper tool for this ,it is like a screwdriver but the blade is curved,i personally use a screw driver guided by a pair of pliers ,when the spring 'twangs' so does your temper!
regards
joe
regards
joe
- coaster
This method works for me too but I'll be trying Byron's method next time I do it. cheers Jarvbristolmod wrote:funnily enough I've just done a mates this afternoon.
Be warned- the spring is strong and it may slip off the screwdriver. Mind your eyes/ body/ fingers- it hurts![]()
As said already, by far the best way is to fit the spring to the stand and frame and then fit stand bolts.
- rog60
- Main scooter: Indian GP200
Same here, by the time you've f**ked about with the spring you could have undone the stand bolts.hydra wrote:As said already, by far the best way is to fit the spring to the stand and frame and then fit stand bolts.
- Andy Pickering
- Main scooter: GP
Ditto...but I did use byrons method last year from his advise cheers byron..rog60 wrote:Same here, by the time you've f**ked about with the spring you could have undone the stand bolts.hydra wrote:As said already, by far the best way is to fit the spring to the stand and frame and then fit stand bolts.![]()
I attach it before fitting the stand.
- Information
Who is online
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 2 guests
