Locking Wire For Exhaust Nuts
GP Rider
Main scooter: GP TS1
I've just converted my downpipe to use a JL exhaust stub.
I'm going to be using the extended exhaust nuts and locking wire.
Can anyone post a drawing or a photo showing the best way to tie the locking wire on.
Many thanks
Chris
some thing like this
jonashford
Gear cable and trunnions
GP Rider
RICSPEED wrote:Image
Hi Rich
Do you leave the ends open or twist together?
GP Rider
jonashford wrote:Gear cable and trunnions
Hi Jon
Can you eloborate?
Thnaks
Chris
jonashford
i use a bit of old gear cable with a trunion to secure it, reason is the wire snaps, or at least it did on mine
GP Rider
jonashford wrote:i use a bit of old gear cable with a trunion to secure it, reason is the wire snaps, or at least it did on mine
Cheers for confirming
Hi Rich
twist together .. i did pic a while ago as same question was asked
Just so I'm clear you twist the two loose ends together?
RManson
I did a story on this a few years back...
http://www.customclassictrucks.com/tech ... ewall.html
Not scooter related, per se, but it more or less covers it. After all, nuts are nuts right? Hope that helps!
    Users browsing this forum: Google [Bot] and 11 guests
