wiring diagram for sip speedo
joespeed
can anyone supply this wiring diagram please?
sideout
joespeed
i need to be more certain of the rev counter connections on the varitronic system,wheres sybil when you need her input!
sideout
joespeed wrote:....wheres sybil when you need her input!
In Germany :?: ;)
The brown wire, which picks up the ignition pulses, is just connected to a 12V AC supply. The only thing you might have to adjust is the pulse number as I believe the Varitronic sparks twice as often as the usual 12V SIL type electronic ignition conversion.
