VBB engine upgrade
AndyS
I have just bought a VBB with standard 150 engine. Only had chance to kick it over and seems to run fine. I'm thinking of upping the power by kitting it, I believe Pinasco do a 2port 177 kit, also upgrade the carb to 24 and upgrade exhaust, change bearings and seals.
My dilemma is would it be worth doing all that to the 2 port engine, or should I just swap it out for a px engine. Would the 2 port Pinasco kit perform as well on the VBB engine as a PX one
Also is there an easy way of updating to 12 v lights etc with the VBB engine and stator
Thanks
Bofs
Stick a P2 lump in it, sorted.
Muffspeed....no muff too tuff
Bad Samaritans SC
1957 Zundapp Betta 500 Auto
AndyS
I know what your saying but the cost of buying the motor, plus then doing everything to it, don't know
Surly you could do everything to a VBB engine that you could to a px, or am I being deluded
mick1
Main scooter: Li Avanti 225
You could probably pick a decent P2 engine for £600 +. Once that's fitted you've no hassle....maybe the wiring but that would give you the 12v system.
The cost and hassle of building a kitted 150 engine doesn't compare (IMO)
Bofs
AndyS wrote:I know what your saying but the cost of buying the motor, plus then doing everything to it, don't know
As Mick says, add up the components,
Kit 200,
Pipe 100,
Carb 50,
Bearings/seals,etc 100.
Gearing and clutch would need sorted...100
Probably a crank too..100
Electronic kit..200
Not worth the hassle
Bad Samaritans SC
guygrrr
Main scooter: 1980 Vespa P187
AndyS wrote:I have just bought a VBB with standard 150 engine. Only had chance to kick it over and seems to run fine. I'm thinking of upping the power by kitting it, I believe Pinasco do a 2port 177 kit, also upgrade the carb to 24 and upgrade exhaust, change bearings and seals.
Thanks
you can have plenty of fun w/ the vbb engine. the vbb crank isn't as robust as the px but there are plenty of ways to remedy that. the pinasco kit is a good addition, it won't be as powerful as it's 3 port cousins but it will be way better than stock. i like the idea of using what you have so i'd recommend the pinasco top end, matching the air box and cases to yr 24/24 carb, get a hold of some 4x8 tires for an easy up gear, and look into getting one of these to up grade yr ignition,
http://www.sip-scootershop.com/en/produ ... r_45135000
more can do, less doodoo.
Juan
Makes sense to me using the Pinasco. Okay it won't be particulary fast but that's hardly the point, useable is enough. And you don't need to go through all the nonsense of having an odd sized and totally differant wheel and if swopping it out stripping the motor to put in higher gearing to allow for the reduced rim size.
AndyS
Thanks for the input, the scooter is already on 10'' wheeled I will look around I think and see what. Available,
Yanker
Pinasco 177 Kit..........200
SIP Road Exhaust........120
Sprint 1 etc Race crank..120
24 carb.......................52
On standard 150 22/67 gearing that should match a P2 performance....easily
Elecronic = + 225 (inc loom £27, switches £25, bulbs £5)
12v only = + 100 (inc loom £27, switches £25, bulbs £5 )
Either way:
+ re-build labour bearings seals and gaskets + eg. cruciform) = say £150
Price of a new P2 lump £1200? if you can find one
Price of a 2nd hand P2 lump £450 requiring a check and build
P2 engine-wise unless you buy new you will have the same re-build costs plus re-wiring costs as stated.
That is as simplified as I can manage ref costs.
    Users browsing this forum: Majestic-12 [Bot] and 1 guest
