hi folks , any idea where i could get one of these ?( the lug the stand spring hooks over )
or what would be the best thing to weld on instead....?
thanks in advance for any help
cheers!
stand spring holder bracket ....lug thing.. on frame
yes , that was the first place i looked ...but they don't seem to have it..
thanks
will weld on a 8mm bolt with a nut run up and welded, to sandwich the spring hook .. but wondered if this may get worn quickly and break
thanks
an m8 cap head is just right, drill and tap the frame m8 ( or weld a nut in) wind cap head in until it traps the spring just right, tack weld from back to keep position, you could use stud lock loctite
high tensile steel capheads are nice and hard so shouldnt wear.
Steve
Steve
