Series 3 engine into series 2 frame.
Ihateyoubutler
Do I need a different kickstart to do this or will the original one off the series 2 engine be ok? The new engine has a gp chaincase if this makes any difference?
Are there any other things that might need altering for it to fit? Not collected the scoot yet (spanish winter model) so trying to plan ahead.
Thanks.
bristolmod
just fit the S2 kick start and away you go
Scootering since 1968.
i think the kickstart stop may be to short as the stop on series two case is different .. just need to extend the stop slightly
Gazbo72
Main scooter: SX200
They do a series 2 kickstart with a series 3/ GP sidecasing. As Ricspeed says the stop is longer.
Gazbo72 wrote:They do a series 2 kickstart with a series 3/ GP sidecasing. As Ricspeed says the stop is longer.
Agreed buzzsolomoto does one seems decent quality :D
Ihateyoubutler
Thanks,as usual,for the help.
The prisoner
Main scooter: Serveta Jet 200
Winter Models did not have already series 3 engine in "a sort of" series 2 frame?
So a "so special" kickstart lever was fitted..?
