Do I need a different kickstart to do this or will the original one off the series 2 engine be ok? The new engine has a gp chaincase if this makes any difference?
Are there any other things that might need altering for it to fit? Not collected the scoot yet (spanish winter model) so trying to plan ahead.
Thanks.
Series 3 engine into series 2 frame.
Ihateyoubutler
- registered user
- Contact:
bristolmod
- registered user
- Main scooter: Lambretta TV175 S3- what else!
- Location: Bali-Hai bar, Locarno Ballroom Bristol, 1967!- mines a Brown Split!!
- Contact:
just fit the S2 kick start and away you go
Scootering since 1968.
i think the kickstart stop may be to short as the stop on series two case is different .. just need to extend the stop slightly
They do a series 2 kickstart with a series 3/ GP sidecasing. As Ricspeed says the stop is longer.
- Toddy
- registered user
- Main scooter: Lambretta Series 1
- Contact:
Agreed buzzsolomoto does one seems decent qualityGazbo72 wrote:They do a series 2 kickstart with a series 3/ GP sidecasing. As Ricspeed says the stop is longer.
Ihateyoubutler
- registered user
- Contact:
Thanks,as usual,for the help.
The prisoner
- registered user
- Main scooter: Serveta Jet 200
- Contact:
Winter Models did not have already series 3 engine in "a sort of" series 2 frame?
So a "so special" kickstart lever was fitted..?
