Is there a test for worn drive side seal??
ssteam177
Main scooter: vba malossi 221, api series2
My engine seams to have burnt 300mls of gearbox oil in 500kms Ive been told since there is no oil leaks it is the drive side seal.
Is there a test I can do before I drop the engine and strip the top end?
Thanks in advance for any advice given
IT'S NOT WHAT YOU BUY
IT'S WHAT YOU BUILD!!!!
Special X
ssteam177 wrote:My engine seams to have burnt 300mls of gearbox oil in 500kms Ive been told since there is no oil leaks it is the drive side seal.
Drain the oil while the engine is ticking over. If the seal is worn it'll start sucking air and speed up. If the engine is burning gearbox oil it will be smoking quite heavily as well.
gerryjunior
Xbox live gamer tag: no
Playstation gamer tag: no
Main scooter: lambretta li 2
put your hand { or whatever you like } over the tip of the exhaust silencer at tickover ,the scoot should choke itself and cut out , if it keeps running the seal is usually gone , and as the previous post says it should be very smoky and smelly if its burning the oil.
Craig H
I tried this but I have a JL3 and it escaped through where end can slip joint is, dam bloody scooters nothing is ever easy :freak:
no need to test further is there after loosing that much oil with no oil leaks ..
tony
Main scooter: 90ss
There is a correct way to do this with tooling.... however... whip the breather off and stick your finger over it with motor running... feel excess of pressure either way?
ssteam177
Thanks for the advice, it looks like I'm going to be busy this weekend then. I was quiet shocked when I went to do the 1st oil change and only about 250mls of gear oil drained out
