tyre & shocks
scooter skin
Main scooter: vespa
can anyone throw some light on a problem i have with my vespa PX 125 MODEL YEAR 2000 please ? i am running on mitchelin Dexter tyres 350.10 and for some reason the edge of the tyre is rubbing against the rear shock and it has damaged the tyre wall i have taken the shock off and ground some of the spring down but its still happening, its not rubbing against the clutch case either so i am lost ??? and now have to buy two new tyres not happy. SOMEONE PLEASE HELP
Boothy_the_makem
Playstation gamer tag: Phantomkiller_uk
Main scooter: modded t5 classic wi a parker
Sounds like you will need a new shock now anorl :shock:
You have tried to mask a fault already there by creating another one .
Your frame could be twisted or the mounting bush for the shock worn.
Some one with more knowledge than ne needs to advise you but i certainly wouldnt have just ground the spring ;)
Canny lass, Geordie girl, he gave her pints and fags and grub and shorts. Canny lass, Geordie girl, she gave him earache and penal warts,Penal warts.
scooter skin
Main scooter: vespa
Cheers thanks for the advice I will have to try and get it sorted.
goldeneye
dexters were my favorite tyre of all time...but havnt been made for what? ten years? and you running one on the back, maybee its perished, or blebbed out on one side? something a-miss if its missing the clutch cover, but hitting the shocker. can you not swap the back wheel for a known good one off a mate to compare?
scooter skin
Main scooter: vespa
I will take a look on ebay and try and find a tyre that is not as wide as the Dexter thanks for the advise cheers
