Brass clutch plunger.
10 inch Terror
Xbox live gamer tag: No.
Hi all, does anyone know roughly how far the brass plunger on GP sidecasing pushes in when the clutch is engaged? I need to do a few measurements before i install a clutch. Thanks in advance Pete.
7mm/8mm roughly though that is with case off mind
10 inch Terror
RICSPEED wrote:7mm/8mm roughly though that is with case off mind
Ok thanks. I'm about to fit a clutch and i'm a bit worried it will go coilbound, as there doesn't appear to be much space in there. I've fitted an AF clutch before and the springs seem almost fully compressed and it was fine, so i'm sure it will be ok.
    Users browsing this forum: Ahrefs [Bot], Semrush [Bot] and 8 guests
