throttle and mot
peterpiper56
Main scooter: li 150 series 2
hello all,new to forum so bit of trial and error, not sure if i asked this question in correct section. so ill try here, would my throttle have to return back in order to pass an mot. at present no spring in place to make this happen, would i have to fettle one, any advice please
Mel K
peterpiper56 wrote:hello all,new to forum so bit of trial and error, not sure if i asked this question in correct section. so ill try here, would my throttle have to return back in order to pass an mot. at present no spring in place to make this happen, would i have to fettle one, any advice please
Don't know but you could tell the examiner it was made that way to enable the rider to maintain his speed while hand signaling a right turn, he'd be stumped as to whether that was right or not. :fb:
mick1
Main scooter: Li Avanti 225
i'd be suprised if the throttle movement was part of an MOT....look on an old MOT and puzzle over where you'ld write "throttle fail"..
peterpiper56
thanks for reply, read other forums and seems motorbikes require it, as for previous mot probably sat in somones house in mumbai. this will be its first here, anyway thanks for reply ill check with garage see what they want
Yanker
Turn the tick-over right up so the lights and horn work: he'll choke before he wants to even think about touching that throttle! LAMBRETTA REVENGE :baddevil:
    Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 2 guests
