muggy carb help
biddy
help me can't get my head around setting up carb on my muggello 200 running on a 30mm phbh main 107 pilot 50 atomizer av266 starter jet 60 needle x7 2nd top and slide 50 and 42mm ancillotti on a tv200 gear box me thinks may is part of the problem :wtf: so if any of you kind gents can help you have a fiend for life {in a good way :lol: }
cheers
jonnyb
Main scooter: Li150 Special
Hello,
I can only help by telling you what I'm using with the same carb and V4 mugello 200 cylinder, I've used an Ancilloti exhaust but now have a Gori and forget my earlier settings, shouldn't be two far off though :-)
I think your slide may be a bit lean to compensate for an over rich atomiser and needle?
Mines,
AV264
X13 needle top clip, mine has been turned down a little by Jerome at Readspeed so try second clip or second clip with a half washer.
45 slide
118 main
53 pilot
Hope this helps :-)
biddy
cheers jonnyb for the rely will give that go
cheers
joey
...gear box is too high geared in fourth...mugello likes to rev....recomend tv175/sx200 std sprockets or gp 200 18/19x47...your carb is way out..put it on rolling road...
WINTERMODEL150
joey wrote:...gear box is too high geared in fourth...mugello likes to rev....recomend tv175/sx200 std sprockets or gp 200 18/19x47...your carb is way out..put it on rolling road...
GP240
mate Boothy has same set-up but as mentioned yer carb is way off.
50 slide is too lean, 40-45. needle x7 no, x2 or x13, atomizer as266, main115-118, pilot 50-55, choke/starter ok 60.
Jonnyb's set up looks right too but the ancillotti pipe can be a pig to sort.
    Users browsing this forum: Google [Bot], Semrush [Bot] and 6 guests
