cheers
muggy carb help
help me can't get my head around setting up carb on my muggello 200 running on a 30mm phbh main 107 pilot 50 atomizer av266 starter jet 60 needle x7 2nd top and slide 50 and 42mm ancillotti on a tv200 gear box me thinks may is part of the problem :wtf: so if any of you kind gents can help you have a fiend for life {in a good way
cheers
cheers
jonnyb
- Main scooter: Li150 Special
Hello,
I can only help by telling you what I'm using with the same carb and V4 mugello 200 cylinder, I've used an Ancilloti exhaust but now have a Gori and forget my earlier settings, shouldn't be two far off though
I think your slide may be a bit lean to compensate for an over rich atomiser and needle?
Mines,
AV264
X13 needle top clip, mine has been turned down a little by Jerome at Readspeed so try second clip or second clip with a half washer.
45 slide
118 main
53 pilot
Hope this helps
Mines,
AV264
45 slide
118 main
53 pilot
Hope this helps
cheers jonnyb for the rely will give that go
cheers
cheers
...gear box is too high geared in fourth...mugello likes to rev....recomend tv175/sx200 std sprockets or gp 200 18/19x47...your carb is way out..put it on rolling road...
WINTERMODEL150
- Main scooter: lambretta ld auto
joey wrote:...gear box is too high geared in fourth...mugello likes to rev....recomend tv175/sx200 std sprockets or gp 200 18/19x47...your carb is way out..put it on rolling road...
mate Boothy has same set-up but as mentioned yer carb is way off.
50 slide is too lean, 40-45. needle x7 no, x2 or x13, atomizer as266, main115-118, pilot 50-55, choke/starter ok 60.
Jonnyb's set up looks right too but the ancillotti pipe can be a pig to sort.
- Information
Who is online
