Best exhaust for Stg 4 barrel, 28mm delly?
a.j
Got a 42 mm clubman at the mo on my S2, but I'd like a bit more ooommph, without cutting rear board. Its been dynoed at 75 but as we all know thats not a true reflection of road speed. I've got a spanish 150 gearbox. Ideally I'm looking at a general allrounder of a pipe.
cheers.
soosh
If you don't want to cut the rear board then maybe a jl3 curley?
Three pipes I've used are Taff, jl3 and a PM. Good spread of power and will pull 4.8 well 1 or 2up but unfortunately you will need slight trimming on those but worth it.
Spanish Fly
Main scooter: P200e
a.j wrote:Got a 42 mm clubman at the mo on my S2, but I'd like a bit more ooommph, without cutting rear board. Its been dynoed at 75 but as we all know thats not a true reflection of road speed. I've got a spanish 150 gearbox. Ideally I'm looking at a general allrounder of a pipe.
cheers.
Stage 2 specific pipe:
http://www.ekmpowershop12.com/ekmps/sho ... 1308-p.asp
Beanhead
Main scooter: 1970 Lambretta gp
just a note on the curly, i had one on a 225 mugello and it was poo!! grounding issues too, some better pipes out there than one of those.
Facebook - Lee Bardsley
Vesperados S.C
Sent from my PC using My Fingers
col68
Main scooter: lambretta s2 li225 ts1
if you dont want to brake the bank what about a fresco pipe got one on my small bloke gse 200 sil stage 4 with a 30mm phbh, pulls very well from low to 5000 in 4th running in at the moment . :D :fb:
Lamaddict
I've got a similar set up but am looking at the new BGM MB Clubman or if I can't wait any longer the Gori. I don't like the look of those motorbike type exhausts.
a.j
col68 wrote:if you dont want to brake the bank what about a fresco pipe got one on my small bloke gse 200 sil stage 4 with a 30mm phbh, pulls very well from low to 5000 in 4th running in at the moment . :D :fb:
Same kit as me, and I'm running in too. I was thinking of going down the fresco route, is yours under kickstart?
Eibar
Main scooter: Eibar TS1 1966
keep ur current pipe and ditch that spanish 150 box
potato
a.j
Yeah they're not very good I know. Its what I had at the time.
col68
now mate mine is over kick start fresco end can had come off my pipe so i had a scorpion end can and short pipe in stainless steel looks nice :anbrgin; made 1 good pipe out of 2 . 8-)
