info needed
hi all , mazzucchelli gp crank do i need to fit spacers for the piston am useing standerd gp 200 topend has anyone used this typ of crank and our they ok any help would be great .cheers.
- soulsurfer
- registered user
- Contact:
Some good info here...
http://www.lambrettaspares.com/info/lam ... s-+89.html
gaz_powell
- registered user
- Contact:
i`ve stripped several genuine SIL 200 motors - no shims in the crank (as all SIL cranks) and no shims on the piston - piston was Mahle i think
mazz cranks use shims so i would say no to piston shims (i`d personally say no to piston shims full stop) - wider small ends are available if you are concerned.
