info needed
mods64
hi all , mazzucchelli gp crank do i need to fit spacers for the piston am useing standerd gp 200 topend has anyone used this typ of crank and our they ok any help would be great .cheers. 8-)
gaz_powell
i`ve stripped several genuine SIL 200 motors - no shims in the crank (as all SIL cranks) and no shims on the piston - piston was Mahle i think
mazz cranks use shims so i would say no to piston shims (i`d personally say no to piston shims full stop) - wider small ends are available if you are concerned.
