carb info needed asap
Bones
What jets should be in a standard 57 plate PX125.
It has a 24/24 carb is that right?
If the same scoot was to have 177 kit fitted and a Sterling pipe what would the ldeal jets be with the 24/24 carb?
It's been a while since I've worked on a PX.
Got a problem whereby tickover is a little fast then after about 30 secs it dies. It also dies as you start to rev it, OK if you keep it reving!
Any help appreciated
Thanks alot
