carb info needed asap
Bones
What jets should be in a standard 57 plate PX125.
It has a 24/24 carb is that right?
If the same scoot was to have 177 kit fitted and a Sterling pipe what would the ldeal jets be with the 24/24 carb?
It's been a while since I've worked on a PX.
Got a problem whereby tickover is a little fast then after about 30 secs it dies. It also dies as you start to rev it, OK if you keep it reving!
Any help appreciated
Thanks alot
    Users browsing this forum: Semrush [Bot] and 8 guests
