Bitubo front shocks
grimspeed
Main scooter: gp 283 kx
Whats the difference bitween disc and drum bitubos ? Anyone ?
I have a drum set up at the moment and i am going to change to a floating disc !
So the real question is do i need a new front shock or can i still use my old one ?
gaz_powell
I had a drum type bitubo and changed to a old type grimeca set up (criss cross front hub)- onlt thing i had to do was to machine down the head of the two M8 bolts that hold the caliper to the back plate - later changed to a standard vespa disc set with star shaped hub and no additional problems at all
my shock is the one with the remote reservoir
hope this helps
gary
grimspeed
Thanks for that ! Most helpfull !
Fruitjuice
gaz_powell wrote:I had a drum type bitubo and changed to a old type grimeca set up (criss cross front hub)- onlt thing i had to do was to machine down the head of the two M8 bolts that hold the caliper to the back plate - later changed to a standard vespa disc set with star shaped hub and no additional problems at all
hope this helps
gary
Instead of machining down the bolts, I prefer to chamfer the holes in the caliper holder and fit chamfered flush fitting bolts...
