kickstart mod
jason frost
How to get the GP type kickstart working right.
GP one on the right with the ramp as part of the end plate, these never seem to work right and it must put some pressure on the end plate each time the engine is kicked over
cut off the ramp
and shape it up
Inside the GP crankcase side
this needs drilling and tapping to M6 use the Li ramp as a guide
take a little off the shaft to clear the clutch top plate
this new one was also deeper
you can see here the part to grind away
and after grinding
it now fits and clears the bolts
you can now use the ramp to set the kickstart so it kicks at the top and not half way down
with the standard washer it had to much play in and out
so a over size one is fitted
and there you go a kickstart that works hope that is of some help.
Bilko
Main scooter: LI150
As usual, top work Jase.
Bilko's Oily Blog
ArKaTxU
Nice job!
good guide. thanks
I need to do exactly this on my next build. but have an Li endplate so was going to use that.
J1MS
Brilliant......Top class.... 8-) 8-)
rog60
Main scooter: Indian GP200
Thanks for that. Already done it on my GP but the pics and description are first class.
By the way are Indian and Italian end plates slightly different in thickness because I used an Italian GP end plate to cut and had to re-shim the gearbox quite radically on my Indian GP. :?: :?: :?:
J1MS
I dont know if they are thicker, but I believe they are supplied as a machined matching pair, End plate and case....
lockman69
Thats excellent, i was about to ask the very question - cheers
rossi46
Can you still use the orginal GP kickstart ? and just fit the Li piece in the end plate cover ?
