The clutch on my PX200 judders / snatches occasionally when it is let out, especially at high revs, and clunks when changing into a different gear, so I am planning to dismantle and rebuild the engine. I guess a new clutch is required and other bits.
In the past I have done engine rebuilds on other bikes and classic minis and more recently put a recon injector pump on a diesel vectra but apart from a lack of confidence on my part would you consider the dismantling and rebuilding of my PX200 engine a DIY proposition?
When I bought it I was told the engine hadn't done many miles since a full rebore and rebuild with a receipt to prove showing loads of bits fitted (I asume the bits were fitted to the scoot I bought!!) The engine does pull well it's just the clutch and gearchange problems which need sorting.
So is it a big job? and what parts and tools will I need? -apart from a Haynes manual!!
Cheers.
DIY PX200 engine rebuild
phil mcglassup
- registered user
- Main scooter: '91 Vespa PX200
- Contact:
Haven't got it myself,but I have got the Lambretta re-build DVD,found it to be invaluable
http://www.scootertechniques.com/vespa_dvds.html
Sounds like a normal Vespa to me!!
Clunking gears is the norm not the exception and a snatching clutch on pulling away with high revs is inevitable on most Vespas.
philhnottm
- registered user
- Main scooter: px (s)
- Contact:
Being a total spanner nugget i bought these DVDs as even the Haynes manual confused me!DaveTomo wrote:Haven't got it myself,but I have got the Lambretta re-build DVD,found it to be invaluable
Spoke to Ian on the phone first , bought the dvds spot on for absolute beginners like me. Well worth the money.
Phil
same here bought the dvd watched it while i was on the sick spot on and easy to understand, would be good if some one did a tuning one any takers?
gaz_powell
- registered user
- Contact:
scooterhelp is a good website to visit if you are just starting
its not a difficult job theres enough info at scooterhelp to do the job and more
good luck
good luck
- rakki
- registered user
- Main scooter: sx|px|rally×2
- Contact:
Basic rebuild of PX200 is so easy that you could do it in the dark while being drunk. Symptoms suggest that the cush drive springs might be broken, drilling the rivets out and assembling new ones can be pain in the arse.
- hobospeed
- registered user
- Contact:
There's a really good chance that it's just the clutch causing all your problems and you might not need to split the cases. I find a lot of times it's just the brass pieces in the clutch that cause the lurching.rakki wrote:Basic rebuild of PX200 is so easy that you could do it in the dark while being drunk. Symptoms suggest that the cush drive springs might be broken, drilling the rivets out and assembling new ones can be pain in the arse.
Tim
- hobospeed
- registered user
- Contact:
Tim
paul d
- registered user
- Main scooter: T5 172 Tv 240
- Contact:
I agree with hobospeed . I doubt a full engine strip is required . You could spend alot of time replacing clutch parts or you could just buy a new genuine one complete . What year is your px ?
